help! keys locked in trunk
I am a space shot! I locked the keys in my trunk. ( SC400 1992) Called hubby to come and save me with the valet key. In the mean time I broke in to the car by unlocking the door from the open sun roof, set off the alarm and hit the locking button next to the trunk and gas cap switches. The Valet key wont open the trunk nor will it unlock the lock button. The call to the dealer was no help. Any ideas! I can drive the care using the valet key but cant get into the trunk.
You're lucky you have the valet key. You can either take it to the dealer or call lots of local locksmiths in your area that can make a laser cut key. The valet key has almost the exact same cuts minus one. The locksmith would be able to tell right off the bat where the missing cut is and set you up with a new key.
This happened to me one time. The dealer asked for proof of ownership which was of course locked safely in the glove box. So I went to a locksmith that did laser cuts for Lexus and only charged me $50 for a new one without a remote.
You just need to unplug wire at trunk switch. Now You need to use long pice of wire and ground one end and touch wire in the unploged connector and the trunk will be unlocked.
lol this actually happened to me yesturday
i just unplugged the siren infront of the radiator from underneath and then i unlocked the doors with the crack in the window, unlocked the door/opened it, took off the battery, and then went through the sub
remove the driver side kick panel, and jump the wire there.
you'll need the pin out for the plug, but it's easier than taking apart the lower dash to get at the lock/switch piece.
either that or get a key cut
a lot less risk of breaking or damaging something while going through the sub, and a lot less work.
Thanks guys, you all have been a great help. Looks like i'll take the car to the dealer. It is drivable with the valet key, it's a bummer that I locked my business supplies in the trunk.
I must admit this is the first post I have made on this forum but, I have check it out many times. The SC400 is an awsome car! WE bought it used 7 years ago and drive it daily. It is now time for a few updates and new paint. I be on the site doing research! Thanks again
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Ok ,I took it to the dealer. They had the keys back to me in an hour and a half. Had a lovely light breatkfast in the cooshy coffee bar/waiting area. They only took me for 125.00... not bad, plus they washed and vaccumed the beast. Yea, I took the easy way out.
I wont lock the keys in the trunk again! Thanks again for all your help, this website is now on my faves list.
I am inspired to do a little pimping of my ride!
