Possible ECU probs?
need some advice on my electrical on an sc400 think its in the steering column can any one give me some advice it looses all power and then stars after it sits for a wile thanks
A good place to start would be to take some time to properly explain what's going on.
If you're not going to spend the time to explain the problem, nobody is going to spend any time to help you out.
Keeper of the light
Either way it's either a ground or the ECU, or the ground on the ECU. bad ground that gets hot will increase in resistance and fail, it will work when it cools down. This problem is more typical INSIDE the ecu so either way... it's probably the ECU.
