arp wheel studs
will the ones made for a is300 fit the sc? i did search and there was only 4 threads total and nothing about the sc, seems like there was a guy with a gs that used the is ones. but if anyone has an answer lemme know
Yes, its for the supra as well. Titan motorsports sells the set for the rear for $60 bucks.
Beware, the studs are longer and if you have closed end lug nuts or wheel covers it may not fit or work.
The ARP studs that Titan motorsports sells for the IS and Supra will fit the SC. I have them on mine. You can also call Titan to verify thats what I did.
As mentioned you will need open ended lug nuts.
Also note that the rear studs will be a little more difficult to install.
to do the rears you just have to take apart the hand brake assembly. just make sure you remember where all the parts go. it should take that long to do the rear studs. i did 4 rear studs on an evo recently in about 25 mins for the whole job. the SC should be about 1.5 hours for both sides with a few smoke brakes. ![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
evo rear brake setup is same concept as the SC
LexusJay1
04-24-16 09:05 PM
