SC- 1st Gen (1992-2000)
Supra TT wheels with spacers...
Old 07-22-08, 05:52 PM
rwdanthony
rwdanthony's Avatar
id just get 20mm spacers for the front. and if you want do a lil fender roll for the back.
Old 07-22-08, 05:53 PM
DJ420a
DJ420a's Avatar
Originally Posted by sc300STED
Thanks man. For suspension, I have KYB GR-2 shocks and Espelir springs. I have 275's in the rear.
Glad you got back so quick, Im ordering my Azenis right now, lol.
Old 08-29-08, 12:34 PM
sc.Fred
sc.Fred's Avatar
From reading this thread this is in regards to having spacers while rolling the fenders.
My question is how many mm's am I going to need to the F&R to make it as flush as possible without fender rollin'?
Old 08-29-08, 12:43 PM
ecstaticSC
ecstaticSC's Avatar
Here's my thread https://www.clublexus.com/forums/sho...ight=sc300sted
I installed 20mm spacers on the fronts, fender are not rolled, and I have no rubbing problems. Tire size is 235/45. I will be getting 20mm for the rear also and I will have to roll.
Old 08-29-08, 12:57 PM
sc.Fred
sc.Fred's Avatar
sweet.. so looks like i'm getting a 20mm in the front (hubcentric)
also, since you're getting a 20mm joint in the rear and you're rollin.. would it be safe to assume a 15mm in the rear would suffice without rolling?
from the threads i've seen H&R has been getting the most props as well...
Old 08-29-08, 01:01 PM
ecstaticSC
ecstaticSC's Avatar
Well, I am rolling the fenders because I have 275's in the rear. With a 15mm I think your gonna be rubbing. Maybe if you go with a 255 tire, you might get away without rolling.
Old 08-29-08, 04:05 PM
tcrow31
tcrow31's Avatar
Originally Posted by DJ420a
Not saying your wrong, but that kinda doesnt make since if 5sp_jzz30 is running +20 in the rear and is almost flush. That would mean I would need roughly a 30mm spacer..wouldnt it?
Look at page 2 post 21.
https://www.clublexus.com/forums/sho...=196714&page=2
Old 08-29-08, 04:24 PM
97-SC300
97-SC300's Avatar
will supra wheels with 15mm spacers all around rub with stock unrolled fenders? if you have a decent drop.... nothing crazy like some guys but a nice subtle drop?
Old 08-29-08, 04:58 PM
RotaSpinna
RotaSpinna's Avatar
I'm also thinking about picking up some Supra wheels. Will the Supra brakes fit with the wheels and spacers?
Thanks,
Andrew
Old 08-29-08, 05:24 PM
tcrow31
tcrow31's Avatar
Thanks,
Andrew
TT brakes will work without the spacers. TT wheels are designed to accommodate for the TT calipers.
I believe if you put any spacers on the back wheels it will rub. This is what i hear haven't tried it myself.
Old 08-29-08, 05:26 PM
ecstaticSC
ecstaticSC's Avatar
It probably won't rub if you use 235 or 245's up front and 255's in the back. You might experience slight rubbing on bumps in the rear.
Thanks,
Andrew
Yes, the TT Supra wheels will fit the TT Supra brakes. The spacers will not hit the brakes.
Old 08-30-08, 01:12 PM
roy1928
roy1928's Avatar
is anyone running stretched tires on their supra wheels?
xspsi6
09-19-11 09:20 PM
RX7 RAGE
11-10-09 03:01 PM
soaringsc3
Suspension and Brakes
09-18-08 08:04 AM
RikTT
07-25-07 05:50 AM
MoogieBoogie
Wheels, Tires & Brakes Forum
12-12-03 02:38 PM
Quick Reply: Supra TT wheels with spacers...
