passenger mirror moving with window
is it crossed inside the rubber part where it open/close the door or where it crossed at??
could you elaborate some detail of the procedure, I really need your help, try to fix my too. my is tripping after i install the aftermarket stereo, i think its shoring somewhere but don't know where.
and just a note: i had a really hard time to stick in the speaker wire through the rubber when i run the cables, do you think this is why???
Help me guys!!
Help me guys!!
lil piece of advice for future members that try to run wires thru the door boot. Try to tape up the end of whatever you're using to push the wire thru, and put a lil bit of grease on it or wd40 it helps it slide thru better. i Know some of you single guys have vaseline right by yur bed LOL that works too ... j/k be a lil bit more careful next time guys.
