rain visor instruction
Is there a DIY or english instruction for Rain visor deflectors? I brought the OEM one and the instruction is in japanese, and im kinda confused by looking at the pictures.
If the visors are new they should have self-adhesive on it. Before you peel off the adhesive, make sure you line up the 2 clips included on each side. The clips should be the trickiest part as it clips onto the inside of the rubber moldings. You can also use the cleaning solution that comes with it before installing. Should be pretty straight forward.
which rubber??? the little rubber next on top of the chrome trim??? or the big rubber below the trim?
EDIt, Installed!! yay, thanks, it was below the trim FYI for future installers
SuperCoupe400
08-08-15 09:06 AM
ccdan
06-30-14 06:52 AM
