I installed spacers on my TT rims today...
08-03-08, 09:21 AM
Yea ^^^ what he said. DO the rear!!!
08-03-08, 09:55 AM
Quote:
Originally Posted by
1SickSC
nice and flush! how about the rear wheels?
I think i'll pick up a 20mm for the rear also, but i'm not sure when i'll do that.
sc250tt
Spacers look nice
....You might want to look into getting an alignment .those tires are dead.
Getting new tires is on my "to do list."
08-03-08, 12:56 PM
So you had enough thread left on the stock studs with a 20mm spacer??
08-03-08, 01:09 PM
RX7 RAGE
I didnt bolt the wheel to the stock studs.
I used this kind of spacer, the studs are built into the spacer.
08-03-08, 01:17 PM
you dont need extended studs with bolt-on spacers. alignment will not get affected by putting spacers on. do a 30mm in the rear and youre set.
another idea to consider is to get a pair of TT rears and put them on the front. it will look almost as flush as your current pics without any spacers. it wont be staggered but you can run a nice fat tire all around.
08-09-08, 09:23 AM
So i assume you use the pictured lugs to mount the spacer to the hub?
08-09-08, 11:46 AM
Where did you purchase the spacers from? I might look into picked up a set of these for my wheels. Thanks!
08-09-08, 12:12 PM
dwebb99
Here's a video that shows how the bolt on spacers are installed
mteele
I picked them up from a local member, but he purchased them from Ichiba.
Here, I found a company selling them.
http://www.optionimports.com/lexus3.html
08-09-08, 04:14 PM
They're on ebay for much less....
08-09-08, 04:16 PM
madmax98
The ones on ebay are questionable in their quality.
08-09-08, 06:59 PM
dang, do you have any rubbing problems?
08-09-08, 07:05 PM
Peter_95
No rubbing at all
08-10-08, 07:45 AM
looks good- i ike how it turned out
08-10-08, 10:20 AM
Looks good! If you need an alignment it's because of the lowering not the spacers.
08-10-08, 11:29 AM
thats sikkk, spacers are good for stock wheels only IMO, if your gonna get wheels why not just get the right off set. nice car.
