How can I get my windows up? No engine in car??
Ok so I have my engine out of the car (SC400) and my windows are down.
The car is outside under a tarp now, because I am building my race car also and waiting for parts for the lex. How can I get the windows up?
The only harness that is out of the car is the engine harness.
How do I power the power windows?
Thanks
Josh
Thanks
Josh
you can hook up a 12V power source to the window regulator (after removing door panels). this will make the regulator send the window up or down. reverse the +/- ends of the power source to move the window in the opposite direction.
or with the panels off, you can manually jack up the windows and prop them up with a piece of wood, or a C clamp, etc. be careful not to put too much stress on the cables because they are somewhat fragile
or you could try putting a thin cloth over the very tip top of the windows and pulling them up with a set of pliers?
i do that with my drivers side window considering my regulator just broke and my window will slowly fall randomly
![Dunno](https://www.clublexus.com/forums/images/smilies/13879dunno.gif)
![Thumbs up](https://www.clublexus.com/forums/images/icons/icon14.gif)
Thanks a ton, it worked great! Windows are up and good to go.
THANKS!
Lexus/Toyotas are weird with there wiring, everything is interconnected and ****. If one thing is not connected in the circut, then a bunch of things wont work.
Josh
