? on jdm headlights
question
what is the difference if any between jdm headlights and us version
does our 9006 bulbs fit the jdm housing .. has anyone bought and used jdm version with no issues
i want a fresher set of headlights and the jdm versions are quite abit cheaper
JDM headlights will aim slightly to the right to aim light more toward the centre of the road for a vehicle that drives on the Left Side (Japan / Australia / New Zealand / UK / etc)
USDM are the opposite... your beams point slightly left.
You can get around it by just adding a couple of washers when you bolt in the headlight to correct the beams to suit... may take some adjustment, but asides from that, all fittings are the same from memory
I have 2 sets of JDM headlights. I'm using one set on my car now. They use the 9005 bulbs.
I also have an ebay plug and play hid kit. They show great with a nice cut off line. I know it's nowhere near a retrofit but it's all I need. I haven't been able to compare it with a USDM headlight though because mine came with the car.
I don't notice the aiming to the right. It looks pretty centered to me.
