trunk lock on the kick panal
i tried searching but nothing, so all i have is a valet key on a sc i just got. and the lock on the kick panal was pushed in, is there a way for me to unlock it without the master key?
I have no idea, but try getting in there and if its anything like an ignition you should be able to turn the back solenoid with a flat head. ( Ignition i refer to is off a 240) Just giving suggestions.
umm you can also get a push button and ghetto rig it like that. I forgot the colors of the cables you need to connect to get it to pop open. I know I did this when I couldn't find my key. Good old alligator clips did the job. (removes the security that Lexus put on it.) I found the key was under the seat not the trunk.
wow that sounds almost too easy as if there has to be a catch, but i just called kerny mesa lexus and cost about 55 bucks for a flat master key, ill be getting one but ima look under the kick panal for the mean time.
