paasenger window stuck
my driver window is stuck 3 quarters the way up. cannot manually lift or lower the window. I here the motormoving something uo and down and then stopping quickly, and there is pressure on the window. but the window won't budge. ANY ADVICE OR IDEAS???? Thanks linh
do a search. probably the window regulator - test by applying 12V power to the regulator itself.
in the meantime take off the door panel and manually prop up the window with a c-clamp or broomstick or whatever you'd like
