ok so i need help please help me. i have a 95 sc400 and i set up an electric fan the same way jibby from lextreme did but i cant figure out the wiring. my first thermo switch burnt out. and my second. so i connect a switch and i ended up with more problems. it worked fine for 2 days but today the fuse blew. so i changed it... and it blew again. every fuse blew. with the car on and off. every fuse from a 10 to a 40.
what can i do?
how should i wire it?
whats the best positive to use?
what size wire should i use
thanks
sam
fisrt off i know what you mean it happend to me. what fans are you using when i ran into the same problem with the fuses blowing i redid everything. the problem with the fans is they draw to much amperage becuase it configured 2 fans in to 1 so what i did was have to relays and split the fan wiring into 2 so each fan has its own relay so it wont use that much current. i can draw you a skimatics of what im talking about or just take puics of my set up to show you step by step
