SC- 1st Gen (1992-2000)
a different route to installing clear corners $30
Old 09-11-08, 12:24 PM
vipsoarer
vipsoarer's Avatar
Default a different route to installing clear corners $30
Everyone has their way of doing them but i wanted to be able to bolt and unbolt the lights in case i get the bumper repainted or buy a new one so i combined the gs clear lense and the sc housing to do so. Here is how i did it, sorry the pics suck i took them on my phone...
first here is the kit that i ordered. It came with the lenses and 2 bulbs.
next i noticed the lense wasnt glued very well in this kit. i used my fingers and basically pulled the lense off the housing.
both done
notice only the long sides had glue on them which is not good if you plan on just shaving the side to install them. these defn needed to be resealed.
My old amber corners were brittle from being 15 years old so i took a screw driver and shattered the lense and removed it carefully.
Next i cleaned up the edges and then painted the housing in high temp aluminum
notice how the original housing and lense dont fit at all. there is nearly half an inch of excess on the gs lense.
Old 09-11-08, 12:28 PM
vipsoarer
vipsoarer's Avatar
then i glued the badboys up with some hot glue and a glue gun
after getting three sides done here is the excess. i trimmed this on my band saw.
finished off the last side
a little shaping goes a long way for looks
rebolted on and ready to go
they look pretty nice and mock the factory pattern but in white which looks better in my oppinion.
and now a quick teaser of something ive been working on putting in next... a set of 2004 civic si seats.
produced by recaro for honda and have alcantara bolstering and the mesh fabric will match my carbon fiber on my interior
Old 09-11-08, 01:21 PM
OneJay
OneJay's Avatar
Looks good man!
Old 09-11-08, 01:37 PM
Hil
Hil's Avatar
nice job! looks good
Old 09-11-08, 01:44 PM
SClean4
SClean4's Avatar
Nice tutorial/write-up/DIY and nice new method/technique of using the old housing with the new clear lense/cover. Looks good
Old 09-11-08, 02:18 PM
pnyboy27
pnyboy27's Avatar
nice write up! i like your alternative..post up more pix..especially from a distance..id like to see how it all looks
Old 09-11-08, 05:12 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
I like the fact you didn't use crystal clears, which I despise.
Old 09-11-08, 05:38 PM
aka paco
aka paco's Avatar
thanks for sharing this, i like this way much better, i didn't really like that crystal clear inside look, and i like the fact that you use the oem SC housing..
I was unsure about getting these clears, but this way i'm gonna order some now
Old 09-11-08, 05:43 PM
JDM
JDM's Avatar
Beautifully done. This is a much better way to do clear corners IMO.
Old 09-11-08, 09:43 PM
Billy305
Billy305's Avatar
I would also like to see these from a little farther back. Good job on the install!
Old 09-11-08, 10:30 PM
pnyboy27
pnyboy27's Avatar
so those were from the gs right? just to make sure..what year?
Old 09-12-08, 05:57 AM
vipsoarer
vipsoarer's Avatar
Thanks guys i appreciate the compliment. I am with OLT in saying that i much rather have the ones i got just because i think it matches the rest of the car's lighting better. I will take some more pics from further away once it stops raining in a couple of hours. I tested them yesterday in the heat by running them for a while and no issues and this morning on my way home in some crazy rain and they arent letting any water in. So far so good.
pnyboy27: you are correct these are from a second gen gs. If you look up gs300 clear corner on ebay you will see them.
Old 09-12-08, 07:46 AM
rwdanthony
rwdanthony's Avatar
gives much more of an oem look! better then those inside crystal clears
Old 09-12-08, 09:02 AM
vipsoarer
vipsoarer's Avatar
well it hasnt stopped raining and it doesnt look like its going to for 2 days, 100% chance of precipitation for the next two days so i took a couple more shots when the rain let up some.
Old 09-12-08, 09:03 AM
SC_coupe
SC_coupe's Avatar
Well done, probably the best-fitting GS sidemarkers I have seen.
Quick Reply: a different route to installing clear corners $30
