SC- 1st Gen (1992-2000)
fender rolling????
Old 09-30-08, 11:18 PM
ekrebs
ekrebs's Avatar
Default fender rolling????
alright i need some advise on fender rolling! what is the best way to do it, or most effective way of doing it?
i have 275s in the rear and the are rubbing bad!
Old 09-30-08, 11:34 PM
DY3VERSITY
DY3VERSITY's Avatar
Baseball bat.. or take it to a good body shop
or
eastwood roller. That's what i used before i had it cleaned up at bodyshop
Old 09-30-08, 11:39 PM
twizted
twizted's Avatar
hammer
Old 09-30-08, 11:42 PM
One HoT
One HoT's Avatar
The rear fender is very hard to roll..The metal is usually thick compared to the front fenders...I would recommend shaving or cutting the fender before rolling..
Old 10-01-08, 12:15 AM
justinSC
justinSC's Avatar
Cut the rear, roll the front.
Old 10-01-08, 12:55 AM
TRD_Power
TRD_Power's Avatar
Can't agree with cutting the rear... If you cut it out then there will be no support and it will fold much easier. Take it to a body shop.
Old 10-01-08, 01:10 AM
justinSC
justinSC's Avatar
What would you be doing to make it fold? My rears are cut and I have no problems with any sort of folding and it feels as sturdy as ever.
Old 10-01-08, 02:13 AM
chrispy
chrispy's Avatar
The rear is two layers of metal. You can shave it to the edge and it'll still be pretty strong.
Old 10-01-08, 05:32 AM
craaaazzy
craaaazzy's Avatar
be careful when u roll. you will get a slight wave right where the holes are for the trim. from speaking to someone about this, they said to notch the hole before rolling to prevent this...i have not tried this but worth a try. all 4 of my fenders have the same waves on them. may have it professionally fixed some day.
Old 10-01-08, 05:47 AM
//LRD
//LRD's Avatar
Cut the rear and roll the front
Old 10-01-08, 06:02 AM
1985zcar
1985zcar's Avatar
Free way is a heatgun and a hammer.
Right way is Fender Roller/heatgun.
Other way is cut out the lip.
Old 10-01-08, 07:48 AM
ekrebs
ekrebs's Avatar
What do you mean by "notch the hole"??
Old 10-01-08, 08:46 AM
craaaazzy
craaaazzy's Avatar
from my understanding, you need to cut a segment from the whole out to the outside of the lip.
Old 10-01-08, 08:50 AM
ekrebs
ekrebs's Avatar
Has anyone pulled the rear fenders? is it a good idea?
Old 10-01-08, 09:54 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
The bat is the easiest way, but if you crack your paint you'll be pissed so use a heat gun and go slow.
Quick Reply: fender rolling????
