SC- 1st Gen (1992-2000)
Drive Thru Carwash = :(
Old 10-01-08, 03:23 AM
PecosBill
PecosBill's Avatar
Default Drive Thru Carwash = :(
So on my way home last night I stop to get gas and decide to run my lexy through the car wash real quick. When I get home I notice my drivers side headlight looks all hazy. And now this morning it looks the same on the passenger side. Has anyone had this happen to them? Ive opened the headlights to paint them awhile back and have washed the car a lot of times since then without any problem of moisture getting in, including going through drivethru car washes. Whats going on?
Old 10-01-08, 05:51 AM
schwarz
schwarz's Avatar
Is the hazing on the inside or outside of the lens? If the outside, it is most likely caused by the waxes they use. Was a common problem on my car until I stopped getting 'The Works' at my neighborhood touchless wash (with foaming wax, clearcoat sealant, etc.).
Old 10-01-08, 06:44 AM
SC_coupe
SC_coupe's Avatar
Last time I took my SC though a car wash, the purple soap they used ended up drying up inside my headlight
My fault for not handwashing....
Old 10-01-08, 07:55 AM
//LRD
//LRD's Avatar
Big amen to that bro.Same sh_t happen to me last week.
Old 10-01-08, 08:34 AM
captainsc
captainsc's Avatar
Yeah just try to buff the outside of the housing first, if not you might have found a leak...
Old 10-01-08, 09:53 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
It simply found a problem you already had. By applying more water it soaked leaks in the headlight that you normally don't get with just a little hose of water.
Old 10-01-08, 12:01 PM
PecosBill
PecosBill's Avatar
It appears to be on the outside. Im gonna try the ol' toothpaste/polish trick and see if I dont get some decent results
Old 10-01-08, 04:00 PM
sc250tt
sc250tt's Avatar
You might have to reseal the lights. Mines does the same when it rains .
Old 10-01-08, 05:04 PM
MEANDAFAKA
MEANDAFAKA's Avatar
i would never put my lexus through the drive through wash.
Old 10-01-08, 05:08 PM
TRD_Power
TRD_Power's Avatar
You're best to never use a drive though wash, man. Sorry you had to find out the hard way. I'd look for scratches on the paint as well.
Old 10-01-08, 06:05 PM
Matador
Matador's Avatar
Yeah I was in a pinch and did a drive thru and had the same thing happen despite no condensation from previous washings. I took out the head light and did a quick semi-ghetto mod to allow for more airflow so water would evap quicker. Worked great thus far, still need to test it out with a good washing though.
Old 10-01-08, 06:56 PM
PecosBill
PecosBill's Avatar
Good news everyone. Toothpaste and polish did the trick, it was just some hazing on the outside, no inside moisture. I guess they added something to the wash mix like Schwarz said.
BTW it was a touchless wash, no spinning plastic or "brushes" just water jets and soap so my paint is a-ok
Old 10-01-08, 07:08 PM
Kaydee
Hacked CL to become a Mod
Kaydee's Avatar
are you sure? touchless car wash usually use stronger detergent to clean the car, and may have stripped any kind of protectant from the paint. I'd say you wax it right away
Old 10-01-08, 07:46 PM
PecosBill
PecosBill's Avatar
Touche' Kaydee. I was merely referring to TRD Power's comment to check for scratches
Old 10-02-08, 11:25 AM
jrbury3
jrbury3's Avatar
I used to have a customer,Sonny's Enterprises, that said go brushes over touch free. As long as you go to a reputable car wash (does maintenance, replaces brushes, etc...), it's a better wash and safer. Said that the high pressure is more harm then good for the paint. Don't think he was busting my *****, haven't been to a brushless since.
Quick Reply: Drive Thru Carwash = :(
