Cabin Air Filter for SC400/300 92-2000 Exact Fit!
I finally found the correct air filter for my 92 SC400. Denso provides original parts right from the factory for the 92's - Here is the website: http://www.densoaftermarket.com - the part number is: 453-1003 - I have a pic showing the filters. It comes with installation instructions. When I checked out to buy the part I was re-directed to: http://sparkplugs.com -
![Woot](https://www.clublexus.com/forums/images/smilies/woot.gif)
We had a couple threads on this -- here's a scan of the instruction booklet if people want to see how to remove and replace the filter: https://www.clublexus.com/forums/sho...19#post3373167
pnyboy27 - The cabin air filter is located under the kickpanel under the glovebox as seen in the link.
These filters are hardly an exact fit for the 92's as CAF's werent spec'd until 93 MY if you look at the post its for 98 SC. They all require trimming for the 92's. This has been discussed a bunch of times.
Good luck.
Good luck.
Once you drop the kickpanel under the glovebox you'll see almost in the center 2 wingnuts remove them and a small panel will drop, thats where the filters go. There may or may not be anything in there i had some debris and 2 of the 4 filters.
I got mine from the toyota dealership for $45. it came in a toyota box with denso instructions.
its alittle cheaper on the website but after shipping comes out to only $2-3 less then what I spent.
sjc2467
Performance & Maintenance
04-21-13 07:24 PM
