Pay it forward! Community spirit thread.
#377
Keeper of the light
Guy's do please respect persons wishes on their local policy to avoid wanted style posts. Do feel free to PM them to ask rather than post if you must bother trying to get them to ship.
#379
driver side 92 sc400 front lower control arm with ball joint/boot in excellent condition (no play, but are easy to rotate), has 184k miles on it. will post pics if someone wants. the bushings should be replaced with some polyurethane ones. The camber bolt seized in bushing so i had to saw through it. if someone needs a cheap replacement arm and can push in poly bushings this could work.
seattle area for pickup
#387
92 sc: dash(vents in pieces), rear upper and lower side panels(interior), front passenger door panel, a pillars, center console, seat belts(some tabs broken), misc trim pieces and handles. all grey, all free to a loving home
socal pickup
on a different note. if anyone knows of a local shop that can wire power folding mirrors, id appreciate some refs
#388
I have a couple things. Parts would need repair though. Have a customer returned OEM heater control valve for an SC400. Heat works and everything but the unit leaks. Also have an exhaust gas recirculation modulator with a broke inlet still works. Also have a TPS with harness cut off. Dont know if TPS works or not. Shot in the dark. Harness is for calibrating it to spec.
Free stuff if you pay shipping.
#389
#390
i dunno if anyone has any need for this but recently let go of my lex and now am cleaning out the
parts i got leftover.
sandstone beige trunklid - no emblems
upper and lower tan back seats (upper has a tear at the top along seam and bottom has a 1 tear also)
passenger tan front seat ( motor works but has tear on bottom)
cd changer and main stock pioneer amp
metra double din bracket(mounting tabs are cracked but still held)
climate control (works but lcd halfway blacked out screen)
located in sf. ca
located in sf. ca
