SC- 1st Gen (1992-2000)
Pay it forward! Community spirit thread.
Old 01-13-20, 10:20 AM
  #451
FamForce6
FamForce6's Avatar
Originally Posted by RudysSC
I'll have a free (and brand new) water pump as I have to buy an additional one for my GTE swap (it should fit all 2jzge and 2jzgte motors w/USDM style thermostat housing) in order to get the thermostat housing needed. If you're local to Denver and would like to pick it up soon, let me know.
I'm in Denver and I think mine is starting to weep. If you still have it I'd be thrilled to pick it up.
Sean
Old 01-13-20, 04:56 PM
  #452
RudysSC
RudysSC's Avatar
Received 1,202 Likes on 833 Posts
PM sending now.
Old 04-08-20, 07:22 AM
  #453
RudysSC
RudysSC's Avatar
I've got what I believe to be a Denso branded OEM radiator that was used for 1-2 years in my SC300. It works flawlessly, isn't damaged, and doesn't leak. The only reason I removed it is because my GTE swap came with an aluminum unit. It does include a shroud, but a couple of the tabs are broken. I was able to ziptie it and use it successfully no problem. Let me know if anyone is interested in it - I'm in Denver, Co off of I70 and Federal.
O. L. T. (04-08-20)
Old 04-09-20, 11:49 AM
  #454
joe diego
joe diego's Avatar
I got a 92 SC300 throttle body (no tps) and the upper runner
Located in San Diego
PM me if you need it.
Old 04-13-20, 08:59 PM
  #455
Shobbs008
Shobbs008's Avatar
I've got a driveshaft from a 1997 SC400 with the A340 trans as well as a brand new center bearing for it. The driveshaft needs a new U-joint, but otherwise it's fine.
Hit me up if you need either part - I'm in Northern California.
Old 04-14-20, 05:01 PM
  #456
scsexy
scsexy's Avatar
stock intake plastic air hose, stock exhaust manifolds, stock 5speed front half of drive shaft. you pay shipping or come get them, Im in Denver
Old 06-21-20, 02:25 PM
  #457
MikeDGS300
MikeDGS300's Avatar
Default #79
Where are u located I'll take the trunk carpet and other trunk items
Old 06-21-20, 06:04 PM
  #458
Shobbs008
Shobbs008's Avatar
I've also got a Koyo A2062 radiator, which is for a '92-'96 SC400, that is practically brand new. I only used to to test fit in my car to find out that it isn't compatible with 97s (I believe it has to do with the trans cooler) and it got slightly scraped up on the way in the car but there is no damage that would mess with the functionality. If you're in Northern California, you can come pick it up, free of charge, or I can ship it if the buyer just covers shipping charges.
O. L. T. (06-22-20)
ThomasGS4
11-29-21 07:14 PM
lexispoold
SC400 / 300 Classifieds
04-16-15 04:46 AM
ac921ol
10-28-11 12:23 PM
trinituner
09-03-09 08:51 PM
Quick Reply: Pay it forward! Community spirit thread.
