ps - 2jz filteres are a little messy to remove....better line the bottom with towels & get it out quick
Yes that is for sure! Loosen it from the top first and then take it off from the bottom a lot easier to take off once you have done that. Spray it down to get rid of any excess oil. On the SC400's easy work to change the oil no complaints should be make there. The DIY people that is the place to start with the basics. If you are doing things more complicated then that make sure you have a friend or a source where you know your fixing the problem correctly.
