Driver side blinker going fast?
My driver side blinker is blinking way faster than normal. My passenger side blinker is fine. I know this is usually a sign of a short, but the electrical system in my car is stock and has not been touched. It appears that all my lights are working and that no bulbs are out. Anyone have any advice?
Thanks
Thanks
100% you have a bulb out or replaced it with wrong bulb (1157 instead of 2057 etc) I had similar problem with rear tail lamps dash said I had a bulb out but none were out. Turns out the running lamps were replaced with 194's instead of correct lamps.
WOW.. in 6 hours my front drivers side bulb went out :|.. kinda freaky.. it was all good when i was driving back home, then i indicated for the last turn and bam, it was blinking super fast.. went outside to check what's up and i noticed the bulb wasn't blinking.. soo my problem i'm assuming is a burnt out bulb
