Has anyone had their doors adjusted? I know my drivers side needs it because I can really hear the wind, and when I wash it alot more water makes its way to the bottom sill compared to the passenger side.
Does anyone know how much it will cost?
I dunno about adjustment... Check your weather stripping.. I know when I drove mine around when I had it fully stripped I could hear wind from both doors.
They really don't have adjustments for it the door hinges are usualy replaced to take of that kind of issue or saging. That or the door seals are going bad replace those and that could fix the problem.
Guess Ill have to start calling around.
Did he charge you anything? Or was it free since he was putting the motor in?
Nope didnt charge me a penny. So it doesnt require new parts and maybe took 10 minutes...lol...If you cant figure it out ill call him on monday and tell you what he says..
On the hinge itself there is no adjustment. Likely moving the entire hinge by loosening it and sliding it around will make a change, but it really is more of an indicator that the hinge is wearing and will need to be replaced.
