SC- 1st Gen (1992-2000)
djb5118's 1992 Sc300 - Member Journal (56k, eh not a good idea)
Old 08-03-09, 08:08 PM
  #46
djb5118
djb5118's Avatar
Originally Posted by YeA 2jZ
def need to lower the front more but other than that it looks real good. What color is that on your wheels again ?
I know, I'm in the process of trying to figure out why my drop isn't exactly...dropped
The color is Black Chrome powdercoat done by Bonehead Performance here in PA
Old 08-03-09, 09:33 PM
  #47
P.R.S.22
P.R.S.22's Avatar
What suspension are you running? The rear looks good but I'm tryin to figure out why your front is so high When it gets straightened out it'll look real good. Keep us posted.
Old 08-04-09, 08:30 PM
  #48
djb5118
djb5118's Avatar
Its koni yellows with Swift springs...i took the wheel off today and didn't see anything wrong. I may have to get a set of tein (unfortunately eibachs for the supra are now discontinued)
anyways, heres another pic...
Old 08-04-09, 08:31 PM
  #49
ThomasGS4
ThomasGS4's Avatar
WOW that's hella clean!!!
Old 08-04-09, 08:40 PM
  #50
djb5118
djb5118's Avatar
haha its actually filthy, just looks clean when i post such a small image . she should be getting a wash and wax thursday with another shoot to follow!
unless of course you mean clean as in nice, cause if that is the case, thanks!!!
Heres a bigger size...
Old 08-04-09, 08:41 PM
  #51
ThomasGS4
ThomasGS4's Avatar
Clean in every aspect. Bravo man!
Old 08-05-09, 06:16 AM
  #52
YeA 2jZ
YeA 2jZ's Avatar
its so weird that the front sits so high with a spring/strut combo it does looks clean though
Old 08-05-09, 07:08 AM
  #53
djb5118
djb5118's Avatar
I took the wheel off yesterday and everything seemed to be on there as it should. The only thing that I would question is the orientation of the bottom spring mount (aka is it mounted upside down). I don't know how that would happen though.
Anyways, I may end up getting new springs and seeing if that changes anything.
Any suggestions on places to buy them, brand, etc?
Old 08-05-09, 07:10 AM
  #54
YeA 2jZ
YeA 2jZ's Avatar
Espelir ASD
Old 08-05-09, 08:52 AM
  #55
djb5118
djb5118's Avatar
for the supra?
Old 08-05-09, 08:56 AM
  #56
turbodremz
turbodremz's Avatar
looks to me like the springs got swapped from front to rear..I would try swapping the springs around before ordering new ones..there is no way, and I dont care what mechanic says so, that those springs are installed correctly, especially if they were on someone car before with no issues.
Old 08-05-09, 09:08 AM
  #57
YeA 2jZ
YeA 2jZ's Avatar
Nah the asd springs are SC spec only best drop for the price
  #58
Matador
Matador's Avatar
Thats what I was thinking. If they still dont work, you might invest in some coilovers.
Old 08-05-09, 09:36 AM
  #59
djb5118
djb5118's Avatar
The springs are labeled Front and Rear, and I also measured the front spring with a caliper to make sure the thicker, more robust spring was in the right spot. Also, I called Swift to see if they ever had any labeling problems, and they said no (so the springs are not mislabeled at all)
Old 08-05-09, 10:37 AM
  #60
trancuongv
trancuongv's Avatar
something is definitely wrong with the install. i have the same swift springs on tokico illuminas and they are much much lower than yours in the front. and my rear is showing no gap on the fender well. search my name or you can check on the thread that me and turbodremz did. let me know if you need me to check anything on my car.
Quick Reply: djb5118's 1992 Sc300 - Member Journal (56k, eh not a good idea)
