TC and check engine
I purchased the dragon converter from someone on the board and had it installed. everything feels fine but the check engine light comes on after about 15 miles of driving. If I reset, it comes back on in 15. The code is P0770, which indicates a stuck shift solenoid (seems to shift fine) or that the converter is not locking at the speed the ECU would like (seems reasonable). Has anyone with the precision industries dragon converter had a similar problem (96 SC400)?
I really don't want to put another $400 just to put the stock converter back in, that would make it a $1,500 bad experiment.
Thanks,
-Ed
Thanks,
-Ed
oatse:
So, tell us what your impression of the car is now that the Dragon Torque Converter is installed?
Are your gear shift transitions (both up and down) as smooth as they were before?
Am I correct in understanding that the cost to do the installation was $400ish? Who did you have do it?
Originally posted by Red93sc400
oatse:
oatse:
Oatse, what was the outcome?!
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
