yup...i did a visual inspection. turning lamps are good. ill go guy some bulb tomorrow. if it doesnt solve it then atleast i have new reliable bulbs right. My sc is a 93, so are you saying the entire assembly is dead? there is condensation inside...do you think it may be shorting something?
Did you recently change a blinker bulb? If so it could be the wrong voltage bulb.
Had a problem with my tails. Used the 194 instead of the 162 (both bulbs fit in the same spot) and even though all my tails worked the warning light stayed on because of the lower voltage that the 194s produce.
just try changing the bulbs from left side blinker to right side and see if it does the same thing on the opposite side..this will tell you for sure if the bulbs are the problem, it takes mabey 10 minutes, and its free
