1JZ-GTE Single Turbo Toyota Soarer (Lexus SC300)
Thought it might be time to post a little bit about my current project. Funny thing is, how you see it now, is not how it is going to end up.
We just finished all of this and now we are going to tear it down again and rebuild the whole engine with custom wire harness and tuck job with military spec connectors similar to a job we just did on a G35 with RB26 swap and a 1.5 JZGTE setup. Vertex Widebody to come soon also.
ENGINE
Soarer 1JZ-GTE longblock w/ wiring harness and ecu
r-154 Tranny
XS Power T-61 Turbo kit
T4 Manifold – Heat wrapped
3" Downpipe – Heat wrapped
4" Intake pipe/ filter
550cc USDM injectors (Resistors wired to harness)
HKS Style Wastegate
Greddy Type R BOV
600 HP FMIC w/ 3" piping
Act Xtreme 6 puck Stage 4 clutch
Evolution Lightened Flywheel
AAM abs heat shield
NISMO High Flow Fuel Pump
Built alternator to 160amps
Weapon R Coolant reservoir
Blitz Nur Spec Axle back dual exhaust
w/ custom 2.5in. piping from downpipe back to y-pipe
Koyo Radiator
Fan Shroud (powdercoat black)
PHR Upper Radiator Hard Pipe - Polished
Blitz Type 1 Radiator Cap
AAM Radiator Show Plate
Cusco Oil Catch Can
GReddy Oil Filter Relocation Kit
B&M Oil Cooler
Mocal Sandwich plate w/ Thermostat
Driftmotion SS Clutch Line
Driftmotion SS Power Steering Line
Driftmotion Fuel Dampener Bypass Hose
Driftmotion Pulleys
Powerhouse Racing Vacuum Distribution Plenum
Sun Auto Ground System
Sun Auto Voltage System
NGK 6097 Spark Plugs
New Waterpump
New Timing belt
New TT Hoses
New Power Steering Reservoir
New TT Motor Mounts
Odessey 925 Battery
Powdercoat Spark Plug Cover Black
CHROME
• Tow Hooks
• Radiator Brackets
• Turbo Housing
• Trottle Body
• Intake Manifold
• Valve Covers
• Water Neck
• Belt Tensioner
• Power Steering Reservoir
• Intake Pipe
• IC Pipe
• Alternator
Suspension / Brakes
Carbing Strut Tower Bar
Daizen Correction Kit
Daizen Sway Bars
Daizen Steering Rack Bushings
Daizen Control Arm Bushings
LS400 Big Brake Upgrade
Toyota Supra Struts
Tein Springs
Irotors drilled/ slotted rotors front and back
Goodridge SS Brake Lines
Wheels / Tires
RPM R-505 Wheels Chrome
F: 19x8.5
R: 19x9.5
BFGoodrich g-force T/A KDW
F: 245/35/19
R: 275/35/19
Electronics
APEXi AFC NEO
GReddy Turbo Timer
GReddy Boost Controller
GReddy Speed Cut Defencer
Greddy Boost Cut Controller
AAM 4-52mm gauge pod in roof
w/ Nordskog Digital Gauges
(oil temp, oil press., boost, water temp)
AEM Wideband
Viper 791x Alarm w/ remote start
Exterior
Vertex Full Body Kit
Pearl White Paint
Soarer Badging
JDM Wind Deflectors
JDM Side Markers
Audi HID Retrofit
95-96 SC300 custom Taillights
Interior
Black Interior
Lextech Custom 32 blue w/ white waterfall needles Cluster
Lextech Custom blue Climate Control
Lextech custom Blue ODO and Time
Toyota Supra Steering Wheel
Toyota Supra Driver and Passenger Seats
Sound System
Kenwood double din 7” Touch screen Head unit
2-12” Infinity Subs
Rockford Fosgate 1000w Amp
Eclipse 400w/4 Amp
Kicker 4½” front speakers
Eclipse 6½” rear speakers
Phoenix Gold Circuit Breaker
Lubrication
Redline - tranny, diff, water wetter
ATE Blue - brake fluid
Royal Purple – Oil, power steering
CURRENT SPONSORS
All Access Motorsports
SR Motorcars
Vertex USA
Drift Apparel
High End Performance
CarSponsorships.com
FUTURE MODS !!!
Exterior
New Weather Stripping
Vertex Ridge Widebody
Black Pearl Paint
LED license plate lights
***************** Custom LED Taillights
***************** Custom Headlights w/ HID retrofit
***************** LED Fog Lights
***************** LED side marker lights
Interior
Black Leather Interior w/ diamond weave carpet and
inserts (door, and seats)
Vertex Steering Wheel
Vertex Emblem
Vertex Proprius Shift ****
LED mood lighting in interior (door, floor, dome, trunk)
Recaro Seats
Engine
1.5 JZ-GTE setup
ATL Fuel Cell
Cam Gears
ARP Hardware
Custom FPR Kit
FSR Custom Turbo Manifold
HKS TO4Z Turbo
HKS Wastegate
HKS DLI II
HKS 264 Camshafts
HKS Headgasket
HKS or GReddy FMIC
CP Pistons
Clutch (RPS, Exedy, Cusco, Carbonetics, ATS, OS Giken)
LSD (TRD, Cusco, Kazz, ATS, Carbonetics)
Suspension/ Brakes
Ikeya Formula Front/Rear Control Arms
Ikeya Formula Rear Toe Rods
Ikeya Formula Traction Rods
Ikeya Formula Roll Center Adjuster Pillow Lower Arm
Big Brake Kit
JIC Magic Tie Rods
HKS Hipermax III w/ UAS or Airforce Ones Air Suspension
Electronics
Apexi Power FC
Sound System
Custom Sound System w/ 3-10" subs (1 in stock location),
2-7" screens in trunk roof
Wheels - Undecided yet.....
ENGINE
r-154 Tranny
HKS Style Wastegate
Greddy Type R BOV
AAM abs heat shield
Koyo Radiator
Cusco Oil Catch Can
B&M Oil Cooler
Driftmotion Pulleys
New Waterpump
New Timing belt
New TT Hoses
New TT Motor Mounts
Odessey 925 Battery
CHROME
• Tow Hooks
• Radiator Brackets
• Turbo Housing
• Trottle Body
• Intake Manifold
• Valve Covers
• Water Neck
• Belt Tensioner
• Intake Pipe
• IC Pipe
• Alternator
Suspension / Brakes
Daizen Sway Bars
Toyota Supra Struts
Tein Springs
Wheels / Tires
F: 19x8.5
R: 19x9.5
F: 245/35/19
R: 275/35/19
Electronics
APEXi AFC NEO
GReddy Turbo Timer
AEM Wideband
Exterior
Pearl White Paint
Soarer Badging
JDM Wind Deflectors
JDM Side Markers
Audi HID Retrofit
Interior
Black Interior
Sound System
2-12” Infinity Subs
Eclipse 400w/4 Amp
Lubrication
CURRENT SPONSORS
SR Motorcars
Vertex USA
Drift Apparel
CarSponsorships.com
FUTURE MODS !!!
Exterior
Black Pearl Paint
Interior
Vertex Emblem
Recaro Seats
Engine
1.5 JZ-GTE setup
ATL Fuel Cell
Cam Gears
ARP Hardware
Custom FPR Kit
HKS TO4Z Turbo
HKS Wastegate
HKS DLI II
HKS 264 Camshafts
HKS Headgasket
HKS or GReddy FMIC
CP Pistons
Suspension/ Brakes
Big Brake Kit
JIC Magic Tie Rods
Electronics
Apexi Power FC
Sound System
Yes Steve is very open right now. I own a shop in Palm Springs and do a lot of work with him. We just finished building a G35 with RB26 swap and debuted it at SEMA and got offered a couple Magazine covers. Drop by if you want.
its a nice list of parts....
i dont see the reason for the ikeya formula suspension components. they are way over priced for what they are. since you will be on air anyways, no matter what you do to the suspension it wont handle right.
if you are doing this as a shop/show car then cool....keep the updates coming.
btw get a different front bumper/fix it because that gap looks huge.
The kit on the car right now is tore up from Drifting and daily driving... it will be changed when we do the widebody.
This is going to be a shop/show car as well, so that is the reason for the suspension.
Sounds like its gonna be an awesome build. BTW that's a nice looking G35 in the background. RB26 in a G35 platform, sounds like you guys are going with the Top Secret Performance Engineering idea.
Great looking car and swap. Coming from a Nissan background, this is something that makes me tickle inside. heh.
Are you guys going to do something about that wheel fitment?
