Help my batt light is on and brake light too
ok so if i speed up quickly the brake light goes out
as soon as i let off the gas the light comes back on
then after a while to goes out again
all the lights work ive had my friend drive behind me
then this morning my batt light came on
so im thinking that the alt went out
the power steering pump was replaced by the original owner but not the alt
so im guessing after 14 years it punked out![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
so i need advise since i dont want to be stuck on the road
1. Check the level of your brake fluid. If its low, fill it. The brake light should go out. Check your pads before you do this because it might be time to replace them.
2. Go to an auto parts store and they will test the batt and alternator. If you need brakes you are already there so pick some up.
nope brake fluid is fine cheacked that too and added extra just to be shure ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
ok ill have the alt tested ill have to wiat till i have a day off thnx for your imput very helpful
Next thing you can try is checking the sensor on your ebrake. Those are the ONLY 2 things that will trip that light. I'm surprised that it wasnt the fluid. The way you explained it I was sure that's what it was. If its not the ebrake sensor then its a bad sensor in the fluid reservoir.
Anyway, it wouldn't be the bulbs themselves. They wont trip the "BRAKE" light. There is a separate warning light for those.
yepp thats why i thought it was the alt cuss i read some where that they do leak on the alt.
ok so im almost positive its the alt cuss i ran out and looked under the car on my break at work and the alt is covered in dirt build up from that old leak from the power steering pump
Aliga should have an alternator.
https://www.clublexus.com/forums/sho...d.php?t=293883
Might just want to replace both depending on how old your battery is.
Do not over fill the brake reservoir! If you are up to the Full line keep it there. There might just be a loose wire to the sensor since it affected by acceleration.
Then Id say its definitely NOT the battery. Either way get them both tested at the parts store. If the battery is shot Im sure you'll have a warranty on it. You live in a warmer place so Its not likely the fluid level in the battery was affected by temperature.
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
also lexus wanted 600 to fix it
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
thought id use my lexus visa points there
so i guess its auto zone at 100 bucks and 30 for a belt and labor at 80 bucks at a shop i use
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
Caniac14
08-29-14 10:11 PM
