Replace lowbeam bulbs
Hi,
I am new to club lexus, and I used both the search and advanced search functions, but could not find exactly what I need. I drive a '92 SC300.
I want to replace my lowbeam bulb (front, driver's side), but I don't want to follow the advice of the manual and take it into a dealer. Can anyone give me the "dummy" version of how to replace my lowbeam bulb? Thanks for your help!
The lowbeam bulb is a 9006 bulb. All you have to do is simply twist it about 45 degrees and than pull it out. If you look directly on the back of the headlight you will see where to access the bulbs. The inner most one is going to be for the high beams and the outermost one is going to be your low beam.
Thanks everyone! I was able to change my bulb pretty easily, thanks to your help. I turned the bulb clockwise, facing the back of the headlight. I made sure not to touch the bulb, so hopefully it will last a long time. Cheers!
jashtiani
11-10-15 06:50 PM
ThermonMer
11-12-11 01:29 PM
