clutch switch plug
Anyone know what style connecter would fit the plug that connects to the clutch switch?
I've disconnected the clutch switch already and have the paper-clip mod on the plug. So I can start the car without pushing in the clutch.
I'd like to connector into the plug and eliminate the paper clip. this way I can wire in an extension and a cutoff switch somewhere in the car.
There's not much room to work under there and clipping gof the plug would not leave very much wire to add the extension. At least a soldered one anyway since space is so tight
Yeah easiest way would be to just cut as close as you can to the connector and solder it there. To buy another connector really wouldn't be worth it ,but if you want the # I can get it for you from the SC wiring book.
