SC- 1st Gen (1992-2000)
Performance Brake upgrade?
Old 10-18-02, 06:21 PM
  #31
ACleanSC4
ACleanSC4's Avatar
Originally posted by see_fu
the spacers are only temporary till i get the H&R stuff. Hopefully this coming tuesday.
I would post pictures of the car, but it ain't a SC. it ain't even a lexus.
It doesn't matter if it isn't a Lexus...nice cars are always appreciated!!
So putting high quality spacers is ok? What about at high speeds? Drifting? I have some 3mm spacers that I would need if I upgraded to Supra TT brakes, but I'm not so sure about using them for my type of driving. I should probably get different rims then huh? These 18's are clearing it like 18's should.
Old 10-18-02, 09:04 PM
  #32
SL730
SL730's Avatar
Default brembo
Hey, had the same problem when I bought mine a years ago...Everybody told me to go for the front supra brakes...but I needed rear brakes...And a the time my budget was tight so I figured with my mecanic who's a friend of mine that the best would be to put slight upgrade to the rear and in spring (got my car in fall) put the supra brake in front and if necessary upgrade again in the rear. What I did in the end was to put brembo disc and pads (always change both if youre really serious about braking power) in the rear and eventually cross-drilled brembo in the front. We upgraded the quality and performance of the braking system in a very economic way and the car brakes really nice. I always tough early sc don't quite have good brakes for they're weight. To be perfectly honnest, my car doesn't brake like a supra or a porsche (but then again it's not what I wanted out of the car). It's about the same then 300 that you have, wich I test drove recently. My sc now has the same braking power but more endurance I would say (a little). Anyway, depends what you want your car to feel like and what's your budget. That's my 2 cents.
Old 10-18-02, 09:29 PM
  #33
moshlub
moshlub's Avatar
Originally posted by Manaray
No no no...See_Fu's rotors are nice!!
See_fu: Hey bro, NICE setup on the brakes and the wheels! What offset are your Volk's?
I personally like Brembos, but I prefer like the slotted AND drilled rotors (not the particular ones that see_fu has). I was commenting on awj's rotors b/c of the cadmium plating.
Old 10-18-02, 09:32 PM
  #34
see_fu
see_fu's Avatar
I didn't have much of a choice. The only way to get drilled and slotted from brembo is to also get the f50 style caliper. that things just to big and expensive, not to mention they dont offer it for my car.
Old 10-18-02, 11:16 PM
  #35
awj
Bluegr*** Performance
awj's Avatar
That CAD plated brake set is for sale, you know. Brand new in the box.
Old 10-19-02, 12:17 AM
  #36
moshlub
moshlub's Avatar
I _DID_ ask what brand they were earlier in the posts.
Old 10-19-02, 12:33 AM
  #37
DrRick
DrRick's Avatar
moshlub, from looking at the box, i think the rotors are "centric" (never actually heard of them) however they look just like the rotors that i recently picked up from steve ganz and they are race tech rotors. hope that helps.......
Doc
Old 10-19-02, 12:47 AM
  #38
awj
awj's Avatar
There is this button called PM - that is for private messaging. Even though the Doctor managed to notice, I don't think it is because he has a PhD.
Old 10-19-02, 02:11 AM
  #39
DrRick
DrRick's Avatar
thats a D.C. not a Ph.D., awj.
Old 10-19-02, 02:45 AM
  #40
moshlub
moshlub's Avatar
Old 10-24-02, 04:02 AM
  #41
see_fu
see_fu's Avatar
hey, i've been going through all the brake post. If I member right you're running the Ap 6 setup. How's that working out for you?
Old 10-25-02, 07:24 AM
  #42
Manaray
Manaray's Avatar
It's actually working out great! These are AWESOME brakes...however, I am considering switching them out for the Wilwood 6-piston setup...
https://www.clublexus.com/forums/sho...threadid=62047
I am DEFINITELY doing these in my SC400..
2v1g
12-02-16 06:40 AM
daweeze02
Suspension and Brakes
11-14-09 09:39 PM
S to the K
05-23-08 08:47 PM
shoehead
Wheels, Tires & Brakes Forum
09-30-05 12:13 AM
Black_IS300
06-29-01 09:12 PM
Quick Reply: Performance Brake upgrade?
