Highbeam headlight Qs..
Hi all,
new forum member here! Recently bought a 97 SC400, with 90k mi. It runs great and is a total blast. Can't wait to drive it up to Fort Worth for the Christmas/New Year.
I have seen and read a couple of excellent headlight re-furb threads on this forum, but most seem to deal only with the main (lowbeam?) assembly.
My high beams ( the two center ones?) are nearly useless as well. Is there a specific procedure for making these brighter? I am currently using the Sylvania Silverstars.
Thanks in advance for any advice, and I'm realy enjouyng this forum.
Regards,
M.R.
Regards,
M.R.
Howdy Tex!
You're in Killeen, right? Just up the road!
Anyway, I think my highbeams are glass like you say, but my problem is the pathetic amount of light I'm getting out of them.
I haven't removed them yet, but they seem to be reasonably clean, with no condensation, and they don't have a "projector" lens to re-furb. So how do I get more illumination from them?
Gurus-HELP!
Regards,
M.R.
Gurus-HELP!
Regards,
M.R.
you're lucky to have the glass lens on the 97+ highbeam. If there is any type of condesation in the housing I would just take it apart and clean everything out including the projector lens. If there has been no condensation then just leave it alone. As for the brightness issue I would just get some HIDs. That will fix your problem.
I checked the high beams when removing the main pod, and they are indeed glass.
I performed the dis-assembly of the main pod (a pita!) on the passenger side and cleaned /polished the projector lens. We'll see if there is a difference tonight!
Who makes a good HID conversion? How much do they typically cost?
Regards,
M.R.
Regards,
M.R.
Howdy Tex!
Gurus-HELP!
Regards,
M.R.
Gurus-HELP!
Regards,
M.R.
13xus
04-20-10 12:28 AM
