Join me in my interior overhaul....
#143
What are you going to do about the are under the radio and above the ashtray? Also does the head unit stick out farther than the climate control unit or is it flush? You should also polish up the woodtrim. I have a thread on it somewhere and it makes a huge difference!
P.S. I'm in love with the trim job!! Looks excellent!
#144
Thanks - I listed in my mods to do list what I was going to do. I will hit up an audio store and grab a .5 din pocket to put in these. The unit sits between 1/8 and 1/4 out farther than the climate control. I can redrill the holes for the mounting bracket or wait til the dash kit comes out... Have not decided yet.
Thanks
Thanks
#145
Thanks
Thanks
I'm under the impression the dash kit will never come out.
Great work!
#147
Well... I picked up a sub dirt cheap... 2 Alpine SWE's 9/10 conidtion with a box...... so I basically just want 1 sub... and I will seel the other for some dough... Dont need a box or 1 of the subs.
Anyways, just a little pic. I could of went for something more higher end... but once again.. not too big into audio anymore and it was practically a steal.
#149
i use to have those. that was my first set of subs back in 2003
about the radio mounting and all that jazz. you can use the factory brackets. its a simple iso mount. most toyotas use this.
i think you should redrill the hole to make it sit flush. i had the same issue when i installed my alpine. i had to redrill the hole back about 1/4" or so. no more then that i think. it made it look a lot cleaner and flows better with the center console.
what amp are you running to the sub. when i had mine i ran a 500.1 polk momo to 2 10's just like that.
if you search arounf you might be able to find an old school clarion 5 channel amp. they are great. the speakers are rated at about 50x4...true 50x4 not what your radio says. rpm 50x4. the sub channel was in the 200 watt range. that would be perfect for a nice conservative system.
if i look hard enough i think i might actually still have my old clarion in the attic.
#150
