I plan on putting a JDM Soarer cluster in my SC300 but the seller told me you would need to wire it becuase its not a plug and play. Does anyone know what needs to be done for the JDM cluster to work properly?
a WHOLE LOT. it's definitely not a plug and play. i think i've only seen one car with the conversion done. From what i'm told it was not an easy thing to do
I don't know anybody who's been able to do it before. You would need the diagrams for both cluster. The diagram for the Soarer will most likely be in Japanese, so you'll need someone to translate it for you. Then you must figure out how to match up all the wires so that everything will work. I don't know how you would convert it to mph either. Goodluck, hope you could make it work.
