SC- 1st Gen (1992-2000)
power window help
Old 12-25-08, 01:42 PM
lowkeySC
lowkeySC's Avatar
Default power window help
ok so my driver side window doesn't go up or down with the switch but i can hear the motor click when i push the button up or down. i was driving yesterday on a bumpy road and my window starting coming down. and i try using the switch to make it go up. nothing happened. after a while the window goes down a little more and it just stays there and dosent go any lower. i try the switch again. it works! . . . . but it only moves it up a little bit not all the way closed.
so to make it short.
1.window dosent go up or down with the switch when its all the way up.
2.i can crack the window open 3 inches by using my hand and can put it back up using my hand.
3.when the window goes down 4 inches it dosent go down anymore and i can put it back up to 3inches with switch.
what could be the problem?? thanks.
Old 12-25-08, 01:45 PM
aliga
Former Sponsor
aliga's Avatar
you need the window regulator, i have it 85 shipped complete with the motor
Old 12-25-08, 09:56 PM
GS4VIPbOSS
GS4VIPbOSS's Avatar
Wire in door harness for window may be cracked and working when it happens to make contact.
Old 12-26-08, 10:49 AM
o_mtz16
o_mtz16's Avatar
my driver side works but it goes up or down very very slow.
ccarruth
06-04-19 03:58 PM
jamesare
08-12-13 12:52 PM
bcorreia
06-23-10 09:34 PM
dr.300
02-19-10 02:39 AM
edgy
RX - 1st Gen (1999-2003)
02-02-10 12:00 AM
Quick Reply: power window help
