greddy exhaust/toyomoto 1.5 questions
just a couple questions about the toyomoto kit...
does the kit include a turbo type manifold...or will that have to be purchased somewhere else? Ive also heard of people changing the turbo in the kit to a T-60...why is this desirable and how much more is it going to cost?
my other question is about greddys SC300 catback exhaust system...can someone with this exhaust system tell me what its like? Is the sound intrusive? Is it quiet when cruising...etc...
thanks a lot
thanks a lot
you are in luck i have everything you are asking. First the exhaust is nice and quiet when its supposed to be. It doens't get on your nerves but has a nice sound if you rev hard.
the turbo kits come with a manifold...
( just out of curiosity how else are you going to go turbo if a kit doens't come with a manifold??)
you can go with a t60-1 which is still a relatively small turbo that spools pretty fast and has pretty decent power.
you can choose from clutchmasters clutch, RPS, or VITEK. i am trying Vitek on mine... will update on how it drives when i get my car back tommorrow
Arthur
Arthur
thanks a lot for your reply
i asked the question about the manifold because I was told that i would have to find a custom turbo manifold...so basically i heard wrong
...thanks again
ummm I'd like to speculate here
the T60-1 is HARDLY a small turbo
its fricken huge... its a T-series Garret; which means it has a 4" inlet and is a good bit larger than a T4
It spools decent because the A/R on the exhaust side is so low
cundiffw:
the normal kit comes with a T04E-60 turbo; which has a 3" inlet, etc.... its a decent size turbo... the T60-1 is a much bigger turbo; it has a 4" inlet and MUCH larger compressor housing; this is the smallest turbo of the T-series; but its still very big. the .58 A/R allows quick spoolup on the Stage 1.5 setup... although you can order larger A/R exhaust sides for the turbo if you wish...
a ball bearing option is also available for this turbo
to see everything about Garret turbos: http://www.turbocharged.com
cundiffw:
can someone tell me exactly what is included in the kit? I ask this mainly because im wondering if i should get fuel controller, boost controller, aftermarket wastegate etc...
thanks a lot
-Bill
thanks a lot
-Bill
The stage 1.5 kit includes everything... Right down to the clamps, hoses, fittings, etc. Mine included the Haltech F5 auxiliary fuel injection controller (fueler), two 550cc extra injectors (two 550ccs are not needed for 350rwhp, but useful if you're gonna run race gas, higher boost or NOS).
Items NOT included in the kit: some specific tools, like a hole saw and some odd sized drill bits. You'll need to rent a 90 degree angle drill for the boss on the block that you have to punch through. Clutch is not included. (absolutely need the best clutch possible---the RPS that I have is pretty crappy, chatters, doesn't always hold the 425-525rwhp very well). Gauges-- You'll want air/fuel and boost gauges as an absolute minimum. An EGT gauge would be highly recommended and best installed with the kit. Lance can cut an appropriate hole before the turbo on the manifold for the EGT probe. Best to do this BEFORE you start installing everything.
Items NOT included, but are almost essential: MSD 6BTM ignition box... You'll WANT this item if you're running stock compression, otherwise you won't be able to selectively retard the ignition. Boost controller: I love the Apexi AVC-R... It allows RPM based boost and gear based boost functions that allow you to squeeze that last bit of power out of the engine under stock compression. I believe Computerwiz also has the AVC-R, he's on a smaller turbo and still managed big power in part because of the AVC-Rs RPM based boost.
Some of the install process and parts are listed on my site:
www.datapathusa.com/scott/scott.html
Feel free to ask any questions1
Rob_O
I'm not aware of the J&S doing anything to bump up the spark. Have you had problems with misfiring with the plugs gapped down? At what boost level did it become a problem?
Rob_O
Rob_O
No real misfires, just drivability issues. With stock ignition, it would hesitate when transitioning from vacuum to boost... Typically when crossing the vacuum/boost line. I suppose the MSD box makes a more robust spark that is able to fire a wider variety of mixtures. It feels stronger HP wize as well. I can't say for sure, but it feels like 20hp.
Bean, the MSD-6BTM includes a 6A ignition amplifier, as well as the boost timing master (which is available separately). You won't be able to use it with juice though, it's boost-indexed retard, no way of sensing the flow of nitrous, to do that right you'll need a standalone that will let you map out your N2O flow in conjunction with timing retard in rpm increments, otherwise there's no way for the ECU to determine how much hit is flowing into the motor. I've never gotten more than a couple hp from an MSD, including turbo cars, just did it for smoother running, the ability to fire diverse mixtures, as Scott said, and the hotter spark at higher revolutions, where I get nervous that a single misfire at 6500rpm could be a no-no at a bar of boost. Scott, the fact that you feel you got 20hp is great, combined with the user-controlled retard, talk about bang for your buck, you must be kicking yourself for not installing it sooner. Bean, try a Jacobs nitrous mastermind if you can get it to work with the SC, I believe it has a feature that allows you to retard timing in conjunction with and in reference to progressive nitrous control.
- Jon
- Jon
