Sc300 with Greg Weld drag package pics and info.
Here are a cupple pics of the Greg Weld on my SC.
Specs are: Front 15x3.5 w/ 1.75"bs 25x5x15 tire Hoosier front runner
Rear 15x8.5 w/5.5"bs 27x11.5-15 Hoosier quick time pro
Mods to fit: Front= no modifiations or spacers needed to clear stock brakes
Rear= calipers needed to be ground down flat. Grinding on the caliper brackets slightly to create slight air gap. Rear fender lip will have to be removed completely to fit these tires. If you go with a 27x10.5-15 Hoosier you should not have to do as much fender grinding as the tire is 1" narrower.
Whats needed to make them work: Wheels, Grinding, Hub rings (78.1mm OD and 60mm ID) , Greg weld lugnuts in 12x1.5 with offset washers.
Note: The only way you can get the offset washers from summit is if you order a bag of either 1/2" or 7/16 lug nuts as they come with offset washers. The 12x1.5 lug nuts are not offered with offset washers. I spoke with mike at greg weld and he confirmed this. He said that the washers can be orderd seperately but they are $2.50 or so each from summit. That is the same price as a set of aditional
1/2" lugs and washers ($9.95) for a 4 pack.
Anyhow onto the pics. Sorry for the dirty car pics.
Front wheel
Rear wheel
Lawrence
Front wheel
Rear wheel
Lawrence
Thanks for the compliments guys. I can tell you that they hook awsome. I went to the track a cupple months ago and the car spun through 1st and 2nd gear on the Th400 with mickey thompson dr's.
I took the car out on the street yesterday and it hooked so hard that my head hit the headrest when the car hit 2nd gear, The front end probably came up 6 inches
Who does this SC belong too?
Just wondering who this SC belongs too, it is Ridiculously SICK!!!
Does anyone have more pics? Saw it on SF's
