gated shifter question?
01-12-09, 04:52 AM
i have a 95 sc 400 i was wondering if i bought a gated shifter from lexus would it bolt on?(excluding the wiring) if so from what year?
thanks,
sam
01-12-09, 04:54 AM
why did it block out shifter from gated shifter?
01-12-09, 04:54 AM
you should search, its on here...
01-12-09, 04:57 AM
Neu`roc´i`ty
Quote:
Originally Posted by
sexy sam
You spelled it wrong....you forgot the "F" in shift, popping off the text bad word editor.
01-12-09, 05:03 AM
oh wops is 7am here and i have not slept thank you if you can change the title it would be much appreciated
01-12-09, 05:19 AM
i have been searching and i can not figure this out.
01-12-09, 12:30 PM
It bolts on but it needs some fabrication, rewiring, and some extra manual labor to make it work..There is not straight answer because its not an easy mod to do if you have no experience with it before..As mentioned before, do a search before you try tackling this..
01-12-09, 12:34 PM
Hacked CL to become a Mod
since you're new go search up JesLet gated shifter conversion
01-12-09, 06:22 PM
i saw all the wiring thats not a problem but would i have to cut the shift linkage at all.
thinhthan
Performance & Maintenance
05-29-08 07:58 AM
SilverBolt 219
08-22-03 06:57 AM
LexusGS3
GS - 1st Gen (1993-1997)
06-27-03 03:20 PM
FlyLexus
SC- 1st Gen (1992-2000)
02-01-03 07:38 AM
