SC- 1st Gen (1992-2000)
Climate control STILL stuck at 75 PLEASE help
Old 01-23-09, 08:19 AM
2JZGTE SC
2JZGTE SC's Avatar
Default Climate control STILL stuck at 75 PLEASE help
YES I SEARCHED like crazy. I have a '94 SC300. At first my climate control was stuck at 75 degres, no matter how much I turned the **** around te temp wouldnt move. So I went ahead and baught a new **** mechanism, now I can change the temp from cold to 75, it STILL wont go past 75 degrees.
What do you guys think the problem is now? It must be the main climate control unit right? What else could it be? With the new **** I have all functions except to go pasty 75 degrees. And yes its absolutly freezing in NJ!thanks
Old 01-23-09, 02:36 PM
RedPhoenix
RedPhoenix's Avatar
I was going to suggest a new **** assembly... But since you did that, the chances of it being bad as well are pretty slim. Climate control would be next. Do you have anyones you can test?
Old 01-23-09, 06:53 PM
2JZGTE SC
2JZGTE SC's Avatar
Negative, I dont know anyone with an SC. Thats a great idea though. thanks
Old 01-24-09, 04:13 PM
2JZGTE SC
2JZGTE SC's Avatar
Question
Anyone have any other experiences or input? Is anyone selling an climate control unit?Thanks
Old 01-24-09, 06:26 PM
JspecSC3
JspecSC3's Avatar
Used parts can be purchased through Aliga.
Old 01-25-09, 08:13 AM
tavarish
tavarish's Avatar
most likely the wiring. Mine did that. I checked the connections, and a wire was loose on the pigtail to the ****.
Old 01-26-09, 12:45 PM
durtysc300
durtysc300's Avatar
now mines doin that..fml i just got it "fixed" today too..it was my cig lighter fuse
Old 04-02-09, 11:03 PM
blade80
blade80's Avatar
Talking
wow. good to know what to try. mine has similar problem, will have to try tomorrow...thanks...
Old 04-02-09, 11:06 PM
TRD_Power
TRD_Power's Avatar
At least it got stuck at a comfortable temperature
Old 04-17-09, 03:46 PM
JZCHAOS
JZCHAOS's Avatar
Default fuse
so does the Cig fuse control anything with the CC unit?
Old 04-17-09, 04:01 PM
durtysc300
durtysc300's Avatar
yes it does..i blew the cigarette lighter fuse and my CC would come on just as a blank screen and not do anything
Old 03-25-11, 06:39 PM
durtysc300
durtysc300's Avatar
im gonna bump this since i've been looking and still haven't found a definitive answer. I'm moving to AZ so a working AC would be nice..
Old 04-08-11, 05:20 PM
durtysc300
durtysc300's Avatar
272 views and nothing so far..checked connections and nothing was wrong..could i have shorted a wire? anyone?
Old 04-08-11, 07:12 PM
6SOARER
6SOARER's Avatar
Maybe you have a bad CC unit? Try looking around for a USED unit for a reasonable price in the classifieds
Old 08-16-12, 09:28 PM
durtysc300
durtysc300's Avatar
Okay everyone. I have found the problem. I traced every wire in that harness, everything worked. I replaced my CC unit, that didn't fix it. I never suspected the **** because, it's a rheostat..its just a switch with multiple points..but lo and behold that is the fix. Replace your **** assembly!
Quick Reply: Climate control STILL stuck at 75 PLEASE help
