how do you remove the door panel all the way?
:My window isn't on the tracks right now on the driver door and when I went to pull the door panel off, it was hung up on something right to the left of the door handle on the inside. All the clips were undone and the wire had enough slack to where I know that wasn't the problem. I hope it's an easy fix, but I will be mad if it is and I couldn't figure it out.
door handle screw..i think 4 screws run along the bottom, 2 screws on the front side of the panel(covered by little buttons) 2 under the arm rest..i think thats all of them..and the cables just pop off with some force
