Windhield washer pump?
The winshield washer fluid has suddenly stopped spraying on my 1994 SC300. The reservoir is full so I figure it musy be the pump. Wipers still working but no 'pump' noise when I press the washer button.
1) Could it be something else besides the pump?
2) If it is the pump - where is the pump located and is it difficult to replace i.e. is it a D.I.Y. project?
Banned
The pump is right behind the washer fluid reservoir. its litterly attached to the reservoir. Really easy to replace, just pull it out and put the new one in. Also a ton of toyotas use our pump, so it should be an easy part to find at a junkyard.
PhilipMSPT
06-03-15 11:25 AM
