Fuel gauge sensor wiring
I have a 93 sc300 that was converted to right hand drive. The gauge cluster is from a soarer as well so it's all digital. My fuel gauge never worked. It will flash a few times when I first start it and then go to empty. It always reads empty and I get a message in japanese for it on the bottom of the gauge cluster. When I press the fuel button next to the trip and rest button it displays fuel empty also.
I took a look at the tank and realized that there is 1 wire that was cut. I'm guessing since the conversion was done, they didn't wire the quantity sensor. It's a black single wire. It was pretty long and it reached on the left side of the car under the back seat. The other plugs were connected. So I think the wire should go somewhere on the right side since it was converted.
Does anybody know where the wire is supposed to go to? I hate to guess how much fuel is in the tank by checking the trip odometer all the time.
Thanks in advance.
Here's a pic if that helps.
Thanks in advance.
![](http://i108.photobucket.com/albums/n14/yuhtinkyuhslick/IMG_0781mod.jpg)
do you have the soarer fuel sender? coz i think you might still have the sc sender which i think is the ordinary type sender in most cars (float type). the soarer has this to calculate the exact fuel left:
![](http://soarer.ace.net.au/F-Guage-07.jpg)
it looks quite different from the top:
![](http://soarer.ace.net.au/F-Guage-03.jpg)
