97 SC300 - Help Identifying A Part
I'm absolutely new to doing repairs to cars, new to the forum (glad to be here)...just completely new. So maybe someone can fill me in.
For the ignition, would I have to replace the whole thing or is there a way to buy just the part? If so what is that part called specifically?
Thanks in advance
Thanks in advance
I have some part numbers for you is you can't get them used. This might help you at your local Lexus dealer.
Light ring 81870-24020
color coded trim ring 55445-24020-A2 (Ivory) (92-12/93)
New lock cylinder 69057-24060 will have to be rekeyed by a lock smith to match your current keys. I hope this helps.
I don't think anything's coming apart or detached. But now that I know what I'm looking at & looking for, I'll see if my friend can check it out & properly diagnosis how to fix it.
It still illuminates. It seems to just be missing that piece that covers it.
Okay
I ended up w/the trim ring from Aliga.
I took it to a body shop I've used & the guy says I'm still missing one piece to it, which apparently should be labeled "on" etc, noting the key position.
Any ideas on what this part is called?
ICeD SC300
SC- 1st Gen (1992-2000)
01-16-03 06:15 PM
