2000 gated shifter question
BANNED for ripping off other members
i'm planning on converting to a gated shifter assembly from a 00' sc4. as of now, i believe i only need the actual shifter assembly with its wiring and plugs along with the shift ****. my question is, do i need the cluster to match the gated shifter along with the 00' harness??
in all...am i game with just the shifter assembly (along w/ wires and plugs) and shift ****? or do i need the 00' cluster and 00' dash harness to accurately display gear positioning?
thanks in advanced
thanks in advanced
you need the shifter, shifter bezel, and shifter harness.
Also the 00 has a 5spd tranny where everything before 98 had a 4 spd. so the cluster s display might be different. Just a heads up
thanks in advanced
thanks in advanced
