Help! AC wont work!
Ok, first the ac light went out a couple weeks ago... fine. I'll just get new lights. But now the A/C doesnt turn on. I'm thinking it's just a fuse. I looked in the manual but can't find anything. Do you know which fuse belongs to the AC. Has anyone else had this problem?
Everyone else is just going to tell you to SEEEEEEEEEEEEEAAAAAAAAAAAARRRRRRRRRRCHHHHHHHHH
Check the climate diagnostic system.
I believe you do it by holding in your temp **** and the recirculated air button at the same time, for a few seconds until it beeps.
Get the codes and bring them back to us.
make sure to do it in direct sunlight. Doing it in the evening or at night will throw a code "21" which is for the solar sensor (the little dome by your A-pillar on the driver side).
The lights on your climate control generally wouldn't have anything to do with a malfunctioning AC system.
818sc400
Performance & Maintenance
05-18-08 03:46 PM
