replacing moonroof need help
hey does anyone know how to replace moonroof on the sc 400 i got one from junkyard glass and rack mines was cracked u can email me at trueskater2008@aol.com
Hey welcome to the club. Before posting a thread I would stop and think about what I am going to ask on a public forum. Search to see if its been discussed before by using the search feature. Still cant find the answer to your question? Then go ahead and post.
![](http://i5.photobucket.com/albums/y160/Jspecsc3/Sunroof.jpg)
Replacing the glass is probably the easiest thing I know how to do on an SC.
~Remove the two plastic covers (labeled RED). Be easy because the clips are old and brittle.
~Once you remove those two you should be able to see 2 gold nuts (or 3 depending on what year you have).
~Remove the 2 nuts on each side and push the glass up.
Once you have the glass out remember not to lose any of the silver metal spacers. Good luck.
ohiois350
08-02-09 11:59 AM
