Common maintenance issues?
Originally posted by ToyLexmods
Yeah,
That aint your normal 87 Supra in the above picture. Hehe, I feel pity for the poor fools that have taken this car a 14year old clunker. 70k miles and yes thats factory paint....oh, and that big scoop in the front bumper is straight from Japan...and feeds cold air to my huge HKS intercooler sitting directly behind it. Its got so many discontinued parts imported directly from Japan...the cockpit looks like a jet fighter....
Later gang,
Yeah,
Later gang,
Damn ToyLexmods, that 87 Supra looks frightfully futuristic from the inside. For some reason, I feel like I'd travel back to the future as soon as the car hit 80mph
Lex400
Thanks, it really is a bad *** car. If you didnt know it and were standing next to it....it looks 1year old. Really....not a ding or scratch anywhere.
HKS turbo upgrade package set at 22psi of boost and your at warp speed in seconds. But, you know....I can just as easily cruise the mountains with the a/c on at 100mph and just sit back relax and take in the views. It really is the yeng/yang of cars. hehe
Whoa! So I take it that all of the prices you quote below are for replacement parts, rather than fixing the components that are broken (forgive me if this is a stupid question and things are too hard to fix (i.e. you can't get at the bulbs or something)).
Goodness. So you have to replace the entire gauge and can't just take it apart and solder in/install a new bulb? Dang...
Quick,
Check out the maintenance forum about the needle gauge and the A/C controller. Taka has his site about the A/C fix.
What causes the power steering pump to go? How many miles typically before it goes?
$500 for a hose! WTF?
You can buy a rebuild kit for the P/S pump. Need to have the repair manual. As soon as you get the SC buy the manual for that year.
So you actually need to replace the hinges and door lock? What causes this failure? These are crazy replacement items. Things like this don't happen on my Supras... or my wife's Corolla...
Door hinge can't stand the heavy door through time. The bearing wear out. If you can take the hinge out and repalce the bearing also need to weld the hinge back easy job
So the climate control goes out too?
No, only the LCD leaks so you can't see the number anymore. Everythings else work.
I think I'll try to PM Steve and ask which SC parts people are buying the most... what's his alias?
His name maybe "Supratrd" yes he has a Supra and a SC300, his e-mail:
"STEVE GANZ" <gonzo4u@earthlink.net>
Quick,
Dont give up hope....get your wife a SC4.....its a awesome car. Just find one with good history and not beatup...many of these items will not show up on a clean car. And the fixes are cheap for someone who knows how to wrench...ie climate control is usually bulbs, cheap fix. Get out and drive a few...you will love it. Also, many early 92-94 models had this stuff replaced under warranty so check that too. I do all my own mods/maint and have no problems with replacing anything on my SC...it has not needed it yet...ex for the bulbs in the climate control, 10 dollar fix.
I had a 94tt...sold it...and have a SC4 daily driver in the summer. I did keep my 87T HKS stage 7+ 500hp killer for the days I have an urge to wipe the mountains clean. hehe
You had a 94 JZA80 TT and sold it to keep your MkIII? Was your 94 a 6spd? If your MkIII was your first love I can totally understand that. IMO the MkIII and the MkIV are very different cars (especially in stock form).
Your MkIII looks well-maintained. Nice ride!
[quote] I was only refer only on parts price.
Someone here paid two (RPM and MPH) needle gauges for $350. You have to replace it yourself. There are two more smaller gauges (gas and temp.). The light on the gauges burned out through time. When you test drive a SC you'll know what I mean.
P/S pump OEM ~$450?. Autozone $150
high pressure hose ~$500-$600
low pressure hosw less than above
Door hinge ~$200 each, door lock actuator ~$150 and its a b$%^t to take out.
side power mirror ECU ~$200
Alternator OEM ~too much, autozone ~$189, NAPA ~$200 to $350.
A/C controller, I could of got one for ~$300 (from a Lexus tech., friend of my brother) last summer but I didn't have the money at the time.
CD changer, forget it, go after market. It about ~$500 to $800 rebuild from the dealer. The price depends on which dealer you're dealing with.
Head light: low beam $260, Hi beam $150 (mine was crack, not moisture yet)
The price quote was actual price from Carson Toyota, Steve Ganz (he's a forum member here so we get cheaper price) [quote]
How often do these problems occur? Do they happen in most sc300's??
Matt
Matt
Always good to see a maintanance history on any car.Motor mounts can go,electric dimmable rear view mirror is expensive,windshield is $850+...
Basically a Toyota,so while you already own,you'd know,nothing too very different on these cars.
Is this $850 price from the dealer?
Yea I think I have to go with lex400sc. I have a 95' SC4 and the only thin wrong now with 70K miles on it is the center air vent has 1 crack on it and my power mirror ECU has gone out. Which isn’t a real big problem because I'm the only one driving the car. I don’t have to keep on adjusting the mirrors, but I'm planning to make a trip to the local junkyard and get 1. but other than that the car is perfect. Oh and one more thing on the 95' there is a bit of hesitation when u gently accelerate but u can remedy this problem by putting the car in power mode or by just pushing the pedal harder. Otherwise I have no complaints and I am extremely happy with my SC.
nemisonic
SC- 1st Gen (1992-2000)
08-08-11 11:36 PM
nysupraman
Performance & Maintenance
11-02-06 08:38 PM
