Project Retro Interior.. ohh yeah this will be a long one.
i will be making everything from scratch. First would involve making a sketch, and for a easy skip I'm thing of getting a extra of everything so i am able to not strip my interior while making this. Then use the bolt patterns and door panel to dash curves so there wont be a fitment problem. The design process will be easy just time consuming, ill probably end up making a CAD model of it to figure out what dimensions I will be needing to cut out from wood. Then eveything will be getting a fiberglass layer, bondo and leather fitted.
Making a 300/400 interior look like a 430 interior can be done but will take a pretty good chunck of money. Believe me I have had the same thought too but is kind of expensive. I'm thinking your going to get a 3 spoke wheel with wood on it, take some of the pieces surrounding the radio and climate control in wood, door sills with the Lexus logo, maybe put a navigation unit but have it covered with wood so you don't see it all the time? Gated shifter is a must....probably black and tan combo, thats about all I can think of. Curious to see what you do. Here is a little help with a door sill idea....take some door sills from a second gen GS....just dremel the back down flat and just tape it on our existing door sill. Good luck and can't wait to see what you have in mind.
![](http://i44.tinypic.com/2pt71v6.jpg)
![](http://i43.tinypic.com/acs7et.jpg)
Thanks guys, well in oe of my previous Eagle Talons I started to convert it to celica door panels since the shape was nicer.
but back to this...
Since this will be happening I mine as well go all out on finding the *Perfect* design like mix up everything to get a good idea. I agree with O.L.T. the center console will probably be the hardest part to figure out what looks good.
Heres what i mean by mix
This is just example nothing final.
I like our stock seats so i'm keeping those
09 LS dash design * still thinking about center console.
09 SC door panel
so on, maybe even from different company's
09 SC door panel
