SEM'd Interior + Claiborne Suede FTW
#46
nice, i bet those focal kps sound great in there! you really should remove the plate between the rear seat and gas tank, your sub will sound 100x better. its a pain to remove after youve dynamatted over it (i made the same mistake) but well worth the effort once its out.
#48
I totally think it will sound better but....its a 12w7, how much more can I possible need..ya know?
I wouldnt go that far, but thanks! Its really not that hard....just takes time!
#49
I think you killed my surprise =D. I was planning on wrapping the center console armwrest in suede........and here comes the big if....THE DASH!! I can do it no problem....just thinking if it will look right thats all. The hardest thing with this install is that I havnt used any of that fake microfibre crap.....this is REAL SUEDE. Its non stretchable which makes installation 5x harder, but then again if it isnt hard, then its probably not worth doing right?
#50
Are you using a cow hide? looks like the stuff off of the roll to me. Just wondering because actual suede does stretch the stuff off of the roll doesn't. What adhesive are you using? I again did the same thing on my other Z and it works just fine, but you will have to brush it alot because it gets very dusty there. Good luck man. Seems like you and I have alot of the same ideas.
#52
evileagle. Everything looks GREAT so far but what I really want to see is your JL Audio 12" W7 Set-Up in the trunk. I wanted to use a JL Audio 10" W7 in a sealed box. I was trying to find a way to mount the speaker to the rear deck on the driver side but it look very very hopeless. May be your set-up might offer a new direction.
#59
Well...someone brought up a good point.....About being paranoid everytime someone steps in the car, you are always watching/looking at them to make sure they don't screw something up. Well....after thinking about it, I just decided to at least make the door panels in suede, and keep the rear plastics in SEM because no one ever sits there...I may change my mind and just do it all in suede...I dunno. Well see how it goes. For now im happy with the SEM'd Rear panels.
As for the fronts, here are the new sexy panels........
![](http://i173.photobucket.com/albums/w62/evileagle17/suede/passanger%20door%20completed/passangerpanelfinished001.jpg)
![](http://i173.photobucket.com/albums/w62/evileagle17/suede/passanger%20door%20completed/passangerpanelfinished002.jpg)
![](http://i173.photobucket.com/albums/w62/evileagle17/suede/passanger%20door%20completed/passangerpanelfinished005.jpg)
![](http://i173.photobucket.com/albums/w62/evileagle17/suede/passanger%20door%20completed/passangerpanelfinished006.jpg)
