Let your Lamps BREATH!!
after sealing, resealing and sealing again, i think i'm going to give this a shot. where did you get the small breather? and what size is the are the lines? also i believe it would be breathe..not breath
Unbeknownst to you, this is nearly a direct quote from a post of mine from many years ago.
Here's one from 06 https://www.clublexus.com/forums/1755984-post5.html
I therefore concur.![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
I therefore concur.
I got the filter from advanced auto parts, and i cant remember the exact size of it, but you can make anything in that range work with the right tubing splices. I remember the filter being made by APC. LoL, i just cut some tubing off the roll over here at the dealership, but if you just go to advanced with your car, they can fit you up brother.
Im not familiar with your the tails on your LS, but i dont believe they have breathing vents, you most probably have spider cracks in the plastic. That can be fixed with removing the lense and coating it with epoxy, then sanding back down smooth.
I dont know what your working with, but since it really isnt a place that moisture can get to easily ( your trunk ) then i would be looking for a reason why the moisture is getting there. Are you sure there arent hairline cracks in the lense. If not, after you get the moisture out, instead of a big ole filter like the heads would use, i would suggest for you to look up some Nitro RC foam filters, and mod something up with tubing that would be more like stock.
