Let your Lamps BREATH!!
#47
paco with that much water inside the lense, I think you might have a hairline crack along the seal...mine does not become like that bad if i completely seal the back (my breather is messed up so I just throw out the rubber boot) If I put one on it just fogs up but never condenses
#49
lmao, i just ment it seems pretty extreme going to the lengths of spending $30 on materials and having tubes with K&N style breather filter cones attached to my headlights..
i dunno, knock on woodgrain ever since i've done this they have been great.
#50
#51
Thats awesome bro, you stuffed them with oiled cotton too?
#53
haven't had to yet, we'll see how it holds up when i wash it on a hot summer day lol. btw what kind of oil are you using?
djb, i think it just depends on the moisture, if you have alot you can probably take the headlight off and use a heat gun or hair dryer and blow it on the outside and in the bulb socket holes to dry it, or just leave it out in the sun.. then do the breather filter mod..
if you just have a tiny bit of condensation then doing the mod might clear it up..
my driver side had just a tiny bit and the mod cleared it up..
#54
Sticky red oil like you would use for a NITRO RC motor's filter, or you can use the oil found in K&N recharge kits, something that you have to massage into the cotton and it sinks in.
djb, if your moisture is extreme, then you will need to reseal the headlight, you most probably have a leak. If it just fogs up sometimes, then this mod will fix your problem.
#58
#59
I wouldnt imagine it would have
#60
UZZ30-SC4
what size hose did you use? 3/8" or 1/2"
I'm planning to pick up parts tonight or tomorrow
as I'm cleaning out my headlights now
I already have 3/8th sitting around, so I'm thinking of using that, if you have 1/2" then I'll get the same
hopefully this will be for the last time (or at last for a few years)
thanks for post up the mod
