New spacers for the wheels.
My first set of spacers was only 8mm thick and it did help the stance out but I saw that I could go just abit wider and not have too much issue.
I had my machinist make me these in 11.5mm. The center bore is 60.1mm and the outer bore is 72.6 so I didnt have to buy any hub centric rings either.
![](http://members.***.net/imageking/Hub%20Centric%20Spacer%2011.5mm%20Small.jpg)
I will try to get some of the 8mm on this weekend then post up the 11.5mm on down the road. Not much time now since we are getting a customer car ready for the Supra Meet in Houston next weekend.
I did to be safe.
they actually make 10mm bolt on spacers. i have seen then before. look online. google is your best friend.
slip-on spacers are not a good idea though. too much shear loads on the studs. i wouldnt even take a chance. with the money you spent on having these made and buying longer studs you could have gotten 15mm bolt on spacers.
actually 3-4 full turns is more then enough. dont listen to what "everyone" says.
they actually make 10mm bolt on spacers. i have seen then before. look online. google is your best friend.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
our customer Supra has ARP extended studs and i had him make us a set in 7/16 width with all other measurements being the same putting down 1033WHP through the ARP and these spacers before with no issues
alot of the Supra guys have been doing this to accomodate the 15x10in wheels they run for the drag strip
i have a good relationship with the machinist so cost was good for me as
i help him out in RC racing
working on those car needs some front brakes and getting a customer car ready for Houston Supra Meet so it will be a little while
Mine are made out of MIC 6 aluminum plate. He says if I do need some more made like in bulk he can make them out 6061. PM me or email me at supralative@yahoo.com if you guys have any questions about them
